Ana içeriğe geç
Nokia 3300B SD Card Replacement
  1. Nokia 3300B SD Card Replacement, Battery: adım 1, 2 resimden 1. Nokia 3300B SD Card Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the Nokia 3300B over with the back-side facing towards you.
    • Gently press the button on the back of the battery cover to release the cover and slide up.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 3300B SD Card Replacement: adım 2, 2 resimden 1. Nokia 3300B SD Card Replacement: adım 2, 2 resimden 2.
    • Lift the battery out of the back of the phone.
    • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 3300B SD Card Replacement, SD Card: adım 3, 3 resimden 1. Nokia 3300B SD Card Replacement, SD Card: adım 3, 3 resimden 2. Nokia 3300B SD Card Replacement, SD Card: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using your finger, or a pair of tweezers, press down on the tab below the SD card.
    • The card will pop out of its case. Remove the card.
    • When placing the new SD card in the slot, it should "pop" in.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
George
91 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-65, Johann Spring 2010 Cal Poly, Team 18-65, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S18G65
4 Üyeler
19 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 26
Her zaman: 3,103
