Ana içeriğe geç
Nokia 3300B Screen Replacement
Neye ihtiyacın var
  1. Nokia 3300B Screen Replacement, Battery: adım 1, 2 resimden 1. Nokia 3300B Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the Nokia 3300B over with the back-side facing towards you.
    • Gently press the button on the back of the battery cover to release the cover and slide up.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 3300B Screen Replacement: adım 2, 2 resimden 1. Nokia 3300B Screen Replacement: adım 2, 2 resimden 2.
    • Lift the battery out of the back of the phone.
    • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 3300B Screen Replacement, Screen: adım 3, 3 resimden 1. Nokia 3300B Screen Replacement, Screen: adım 3, 3 resimden 2. Nokia 3300B Screen Replacement, Screen: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Gently push the blue tabs on the top of the phone out of their slots.
    • With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
    • Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 3300B Screen Replacement: adım 4, 1 resimden 1.
    • With the screen still facing you, remove the blue faceplate.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia 3300B Screen Replacement: adım 5, 2 resimden 1. Nokia 3300B Screen Replacement: adım 5, 2 resimden 2.
    • Grab the sides of the keypad and lift it up vertically.
    • If you encounter resistance while removing the keypad, be sure to lift up evenly on both sides, so the button's pin don't snap.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia 3300B Screen Replacement: adım 6, 3 resimden 1. Nokia 3300B Screen Replacement: adım 6, 3 resimden 2. Nokia 3300B Screen Replacement: adım 6, 3 resimden 3.
    • Using the Torx T6 bit of a Phillips precision screwdriver, remove the six screws on the phone's inner protective case, as seen in the picture.
    • NOTE: Be sure to save these screws so the phone can be reassembled later.
    FixBot'a Sor
    Yorum Ekle
  7. Nokia 3300B Screen Replacement: adım 7, 2 resimden 1. Nokia 3300B Screen Replacement: adım 7, 2 resimden 2.
    • Holding the phone with the screen facing you, remove the top half of the phone from the circuit board.
    FixBot'a Sor
    Yorum Ekle
  8. Nokia 3300B Screen Replacement: adım 8, 3 resimden 1. Nokia 3300B Screen Replacement: adım 8, 3 resimden 2. Nokia 3300B Screen Replacement: adım 8, 3 resimden 3.
    • Hold the top half of the phone with the screen facing you.
    • Using a pair of tweezers, release the tabs holding the two distinct cases together.
    • The tabs are very fragile. Be gentle when releasing the tabs.
    FixBot'a Sor
    Yorum Ekle
  9. Nokia 3300B Screen Replacement: adım 9, 1 resimden 1.
    • Be sure to remove both casings so that the screen is facing down. This will ensure that the screen does not fall out of its case.
    • NOTE: The screen's part identification sticker is on the top back side of the screen. The screen will need to be replaced with the same orientation.
    FixBot'a Sor
    Yorum Ekle
  10. Nokia 3300B Screen Replacement: adım 10, 1 resimden 1.
    • Tilt the casing back and the screen should fall out smoothly.
    • Replace the old screen with the new screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Chris Colwell
116 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-65, Johann Spring 2010 Cal Poly, Team 18-65, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S18G65
4 Üyeler
19 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 3,624
