Giriş
This guide walks through the removal of the plastic frame of the phone. Removal of this provides access to the motherboard and most other components.
Neye ihtiyacın var
Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
Bir başkası bu kılavuzu tamamladı.
