Ana içeriğe geç
Nokia 3310 3G Frame Replacement
Neye ihtiyacın var
  1. Nokia 3310 3G Frame Replacement, Battery: adım 1, 2 resimden 1. Nokia 3310 3G Frame Replacement, Battery: adım 1, 2 resimden 2.
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Frame Replacement: adım 2, 2 resimden 1. Nokia 3310 3G Frame Replacement: adım 2, 2 resimden 2.
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Frame Replacement, Frame: adım 3, 3 resimden 1. Nokia 3310 3G Frame Replacement, Frame: adım 3, 3 resimden 2. Nokia 3310 3G Frame Replacement, Frame: adım 3, 3 resimden 3.
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Taylor Lyford
705 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G3, Peak Fall 2018 UMass Dartmouth, Team S3-G3, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G3
3 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 735
