Giriş
This guide will provide you with a step by step instructions on how to replace the motherboard.
Neye ihtiyacın var
Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
7 farklı kişi bu kılavuzu tamamladı.
