Ana içeriğe geç
Nokia 3310 3G Outer Frame Replacement
Neye ihtiyacın var
  1. Nokia 3310 3G Outer Frame Replacement, Battery: adım 1, 2 resimden 1. Nokia 3310 3G Outer Frame Replacement, Battery: adım 1, 2 resimden 2.
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Outer Frame Replacement: adım 2, 2 resimden 1. Nokia 3310 3G Outer Frame Replacement: adım 2, 2 resimden 2.
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Outer Frame Replacement, Frame: adım 3, 3 resimden 1. Nokia 3310 3G Outer Frame Replacement, Frame: adım 3, 3 resimden 2. Nokia 3310 3G Outer Frame Replacement, Frame: adım 3, 3 resimden 3.
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Outer Frame Replacement, Motherboard: adım 4, 3 resimden 1. Nokia 3310 3G Outer Frame Replacement, Motherboard: adım 4, 3 resimden 2. Nokia 3310 3G Outer Frame Replacement, Motherboard: adım 4, 3 resimden 3.
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
  5. Nokia 3310 3G Outer Frame Replacement, Speaker: adım 5, 2 resimden 1. Nokia 3310 3G Outer Frame Replacement, Speaker: adım 5, 2 resimden 2.
    • Using a metal spudger, lodge the tip underneath the speaker and between the soft foam surrounding the screen.
    • Use the metal spudger to leverage out the speaker.
    • The speaker is attached to the shell with an adhesive. Do not be too aggressive in your removal, else the speaker will come apart.
  6. Nokia 3310 3G Outer Frame Replacement, Outer Frame: adım 6, 1 resimden 1.
    • Using your finger, push the keyboard insert out of the front outer frame.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Aaron LeBlanc
723 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G3, Peak Fall 2018 UMass Dartmouth, Team S3-G3, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G3
3 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 932
