Ana içeriğe geç
Nokia 3310 3G Screen Replacement
Neye ihtiyacın var
  1. Nokia 3310 3G Screen Replacement, Battery: adım 1, 2 resimden 1. Nokia 3310 3G Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Screen Replacement: adım 2, 2 resimden 1. Nokia 3310 3G Screen Replacement: adım 2, 2 resimden 2.
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Screen Replacement, Frame: adım 3, 3 resimden 1. Nokia 3310 3G Screen Replacement, Frame: adım 3, 3 resimden 2. Nokia 3310 3G Screen Replacement, Frame: adım 3, 3 resimden 3.
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Screen Replacement, Motherboard: adım 4, 3 resimden 1. Nokia 3310 3G Screen Replacement, Motherboard: adım 4, 3 resimden 2. Nokia 3310 3G Screen Replacement, Motherboard: adım 4, 3 resimden 3.
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
  5. Nokia 3310 3G Screen Replacement, Screen: adım 5, 3 resimden 1. Nokia 3310 3G Screen Replacement, Screen: adım 5, 3 resimden 2. Nokia 3310 3G Screen Replacement, Screen: adım 5, 3 resimden 3.
    • With the motherboard removed, the only thing holding the screen into place is the snap plug on the back of the motherboard.
    • Using a spudger, leverage the top snap up to disconnect it (photo shows motherboard rotated 90 degrees counterclockwise).
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Aaron LeBlanc
723 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G3, Peak Fall 2018 UMass Dartmouth, Team S3-G3, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G3
3 Üyeler
16 adet Kılavuz yazıldı
3 Yorum
If you can break the screen without taking it apart, then you must not be human
Feyrowan - Yanıt
The Cylons are greeting you.
M. H. -
Thank you!
I dont have cash for a new one,
but i could fix my old one.
There was soup on the display inside,
cleaned it, screen is clear now.
Yeay!
fred - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 1,524
