Giriş
If your speaker is no longer producing sound, it may be necessary to replace the speaker altogether. This guide shows a step by step guide to fully access the speaker.
  1. Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. There is a molded notch in the white frame of the phone near the top right of the battery.  Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
    • Using a metal spudger, lodge the tip underneath the speaker and between the soft foam surrounding the screen.
    • Use the metal spudger to leverage out the speaker.
    • The speaker is attached to the shell with an adhesive. Do not be too aggressive in your removal, else the speaker will come apart.
Sonuç
Aaron LeBlanc
474 İtibar
5 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team S3-G3, Peak Fall 2018 UMass Dartmouth, Team S3-G3, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G3
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 25
Her zaman: 66
