Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Guide to replacing keypad of Nokia 3360
  1. Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
    • Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
    • Lift the back plate off the phone.
  2. To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time. To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
    • To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
  3. Lift the battery out of the phone. Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
    • Lift the battery out of the phone.
    • Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
  4. Use finger nails of your thumbs to gently pull apart the face plate. While the face plate is pulled apart, use index fingers to pull inner case towards you.
    • Use finger nails of your thumbs to gently pull apart the face plate.
    • While the face plate is pulled apart, use index fingers to pull inner case towards you.
    • Separate faceplate and inner case.
  5. Gently peel up the edge of plastic keypad from the inside of the faceplate to remove.
    • Gently peel up the edge of plastic keypad from the inside of the faceplate to remove.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Travis Malmgren
69 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 8-39, Regan Winter 2010 Cal Poly, Team 8-39, Regan Winter 2010 üyesi
CPSU-REGAN-W10S8G39
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 3,592
