Giriş
Use this guide to replace the front cover and the keypad of your Nokia 515
Neye ihtiyacın var
Remove the back cover with your fingers or with the eject tool which is included by Nokia.
To remove the keypad, you should use the spudger to push the top clamps down a little bit while pressing your fingers against the inside of the keypad.
The keypad should be loose at the top.
To remove the bottom, just use a little bit of force to pull it off the front panel.
You did it!
You did it!
3 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Leon dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
