Ana içeriğe geç
Nokia 5310b XpressMusic Keypad Replacement
Neye ihtiyacın var
  1. Nokia 5310b XpressMusic Keypad Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the black battery cover down and off the phone with your thumb to remove it.
    • The battery cover is not shown in this picture
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 5310b XpressMusic Keypad Replacement: adım 2, 2 resimden 1. Nokia 5310b XpressMusic Keypad Replacement: adım 2, 2 resimden 2.
    • Gently lift the battery with a fingernail to remove it from the back of the phone.
    • Keep the battery removed for the next steps
    • The battery may be replaced or repaired at this step.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 5310b XpressMusic Keypad Replacement, Keypad: adım 3, 3 resimden 1. Nokia 5310b XpressMusic Keypad Replacement, Keypad: adım 3, 3 resimden 2. Nokia 5310b XpressMusic Keypad Replacement, Keypad: adım 3, 3 resimden 3.
    • On some models, the front case is screwed down from the back. Follow steps 5 and 6 first to remove the camera cover and two T6 screws, BEFORE removing the faceplate.
    • Find a small latch under the music keys and in the middle of each side of the faceplate.
    • Gently lift the edges of the front faceplate off the phone using a spudger.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 5310b XpressMusic Keypad Replacement: adım 4, 2 resimden 1. Nokia 5310b XpressMusic Keypad Replacement: adım 4, 2 resimden 2.
    • Flip the phone over to the front side.
    • Lift up the keypad from the bottom with either a spudger or your finger.
    • At this time the keypad can be removed and replaced.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Max Kirby
518 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-14, Regan Spring 2011 Cal Poly, Team 15-14, Regan Spring 2011 üyesi
CPSU-REGAN-S11S15G14
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 55
Her zaman: 6,560
