Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Slide the back cover down with your thumb.
*Note: the battery cover is not shown in this picture
Gently lift the battery with a fingernail and remove it from its housing.
*Note: the battery may be replaced or repaired at this step
On some models, the front case is screwed down from the back. Follow steps 5 and 6 FIRST to remove the camera cover and two T6 screws, before removing the faceplate.
Use the Spudger to gently pry up the edges of the front face plate
At the center of the faceplate edge below the music keys there is a small latch on each side.
Lift up the keypad from the bottom with either the spudger or your finger.
Note: at this time the keypad can be removed and replaced
5 farklı kişi bu kılavuzu tamamladı.
