Ana içeriğe geç
Nokia 5310b XpressMusic Motherboard Replacement
Neye ihtiyacın var
  1. Nokia 5310b XpressMusic Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the back cover down with your thumb.
    • *Note: the battery cover is not shown in this picture
  2. Nokia 5310b XpressMusic Motherboard Replacement: adım 2, 2 resimden 1. Nokia 5310b XpressMusic Motherboard Replacement: adım 2, 2 resimden 2.
    • Gently lift the battery with a fingernail and remove it from its housing.
    • *Note: the battery may be replaced or repaired at this step
  3. Nokia 5310b XpressMusic Motherboard Replacement, Keypad: adım 3, 3 resimden 1. Nokia 5310b XpressMusic Motherboard Replacement, Keypad: adım 3, 3 resimden 2. Nokia 5310b XpressMusic Motherboard Replacement, Keypad: adım 3, 3 resimden 3.
    • On some models, the front case is screwed down from the back. Follow steps 5 and 6 FIRST to remove the camera cover and two T6 screws, before removing the faceplate.
    • Use the Spudger to gently pry up the edges of the front face plate
    • At the center of the faceplate edge below the music keys there is a small latch on each side.
    Before doing this step, first remove the camera cover and the two t6 screws from the back (steps 5 and 6). Otherwise you will break the cover. This may be a factor only for some revisions (RM-304)
    s c - Yanıt
  4. Nokia 5310b XpressMusic Motherboard Replacement: adım 4, 2 resimden 1. Nokia 5310b XpressMusic Motherboard Replacement: adım 4, 2 resimden 2.
    • Lift up the keypad from the bottom with either the spudger or your finger.
    • Note: at this time the keypad can be removed and replaced
  5. Nokia 5310b XpressMusic Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Gently unsnap the back camera cover from the phone.
    • Lift the cover from the phone after it is unsnapped.
  6. Nokia 5310b XpressMusic Motherboard Replacement: adım 6, 2 resimden 1. Nokia 5310b XpressMusic Motherboard Replacement: adım 6, 2 resimden 2.
    • Use the T6 torx screwdriver head to remove the 2 screws on either side of the camera
    • Flip over the phone and again us the T6 torx head to remove the 4 screws located at each corner of the white keypad base
  7. Nokia 5310b XpressMusic Motherboard Replacement: adım 7, 1 resimden 1.
    • Unclip the faceplate plug (ribbon) located in the lower left corner of the motherboard
  8. Nokia 5310b XpressMusic Motherboard Replacement: adım 8, 2 resimden 1. Nokia 5310b XpressMusic Motherboard Replacement: adım 8, 2 resimden 2.
    • Use the Spudger to pry up the 2 metal clips located near the center of the motherboard on both the left and right
    • At this point the phone should come apart into 2 pieces, the motherboard/LCD screen and the faceplate
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Max Kirby
518 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-14, Regan Spring 2011 Cal Poly, Team 15-14, Regan Spring 2011 üyesi
CPSU-REGAN-S11S15G14
3 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Step 5 and 6 must be performed before step 3, otherwise, you will dislodge the thread from the front plate. so you have to remove the camera cover first, remove the 2 screws then you can remove the front plate without breaking anything.
Vincent Tschanz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 6,841
