Ana içeriğe geç
Nokia 6 Midframe Replacement
Neye ihtiyacın var
  1. Nokia 6 Midframe Replacement, Display Assembly: adım 1, 3 resimden 1. Nokia 6 Midframe Replacement, Display Assembly: adım 1, 3 resimden 2. Nokia 6 Midframe Replacement, Display Assembly: adım 1, 3 resimden 3.
    • Power off your Nokia 6 before beginning disassembly.
    • Insert the SIM card ejection tool into the hole on the left side of the phone.
    • Remove the SIM card and microSD card.
  2. Nokia 6 Midframe Replacement: adım 2, 1 resimden 1.
    • If your display glass is cracked, take precaution by taping over the display to prevent further breakage and harm.
    • Lay overlapping strips of clear packing tape over the Nokia 6's display until the whole screen is covered.
  3. Nokia 6 Midframe Replacement: adım 3, 1 resimden 1.
    • To soften the adhesive, use a heat gun and heat one edge of the phone for five minutes.
    • To use the heat gun, plug it into an outlet.
    • When the heat gun is plugged in, the heat gun automatically turns on and will start blowing hot air.
  4. Nokia 6 Midframe Replacement: adım 4, 1 resimden 1.
    • Take a Jimmy and slide it under the glass after the adhesive has been softened.
    • Place a pick under the glass after lifting with the pry tool so that the screen won't re-adhere to the frame again.
    • Make sure to not touch the LCD edge underneath the glass layer with the metal pry tool or the cards. This can damage the ribbon cables underneath and compromise the structural integrity of the phone itself.
    • The corners of the screen are the most fragile part of the screen. Make sure that the entire edge of the screen is dislodged from the frame before prying at the corners.
  5. Nokia 6 Midframe Replacement: adım 5, 1 resimden 1.
    • Lift the screen off of the phone.
  6. Nokia 6 Midframe Replacement: adım 6, 2 resimden 1. Nokia 6 Midframe Replacement: adım 6, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the 1 mm x 1.4 mm screw holding down the metal bracket over the screen ribbon connector.
  7. Nokia 6 Midframe Replacement: adım 7, 1 resimden 1.
    • Remove the metal bracket with a tweezer.
  8. Nokia 6 Midframe Replacement: adım 8, 1 resimden 1.
    • Use a spudger to disconnect the screen ribbon connector and free the display assembly.
    • The corners and edge of the LCD are fragile. Be careful attaching it to the back of the phone.
    • Carefully remove the screen from the device.
  9. Nokia 6 Midframe Replacement, Home Button Assembly: adım 9, 1 resimden 1.
    • Disconnect the battery connector with a spudger.
  10. Nokia 6 Midframe Replacement: adım 10, 2 resimden 1. Nokia 6 Midframe Replacement: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a Phillips #00 screwdriver to remove the 1.2 mm x 2.2 mm screw in the upper hand corner of the phone.
    • Use tweezers to remove the bracket.
  11. Nokia 6 Midframe Replacement: adım 11, 2 resimden 1. Nokia 6 Midframe Replacement: adım 11, 2 resimden 2.
    • Detach the cable with the black nylon spudger.
    • Detach the home button and remove it from the device.
  12. Nokia 6 Midframe Replacement, Midframe: adım 12, 1 resimden 1.
    • Remove 18 screws.
    • There is one 1 mm x 1.4 mm screw that needs to be removed by a Phillips #000 screwdriver.
    • One of the screws is 1.2 mm x 4.2 mm and will be removed by a Phillips #00.
    • The remaining 16 screws can be removed by the Phillips #00 screwdriver and are 1.2 mm x 2.2 mm.
  13. Nokia 6 Midframe Replacement: adım 13, 2 resimden 1. Nokia 6 Midframe Replacement: adım 13, 2 resimden 2.
    • Decouple the midframe with the spudger and remove the midframe from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chrissy Robins
1.567 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S9-G15, Maness Spring 2019 Cal Poly, Team S9-G15, Maness Spring 2019 üyesi
CPSU-MANESS-S19S9G15
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 620
