Giriş
This guide will help you replace the rear facing camera for the Nokia 6.
Be sure to take extra caution when removing anything from the motherboard.
Neye ihtiyacın var
Insert the SIM card ejection tool into the hole on the left side of the phone.
Remove the SIM card and microSD card.
Remove 18 screws.
There is one 1 mm x 1.4 mm screw that needs to be removed by a Phillips #000 screwdriver.
One of the screws is 1.2 mm x 4.2 mm and will be removed by a Phillips #00.
The remaining 16 screws can be removed by the Phillips #00 screwdriver and are 1.2 mm x 2.2 mm.
2 farklı kişi bu kılavuzu tamamladı.
