Ana içeriğe geç
Nokia 6010 Keypad Replacement
Neye ihtiyacın var
  1. Nokia 6010 Keypad Replacement, Battery: adım 1, 3 resimden 1. Nokia 6010 Keypad Replacement, Battery: adım 1, 3 resimden 2. Nokia 6010 Keypad Replacement, Battery: adım 1, 3 resimden 3.
    • Press the small tab on the bottom of the back of the phone.
    • Push the back case upward towards the power button. The back case will then pop off.
    • It requires some force, so be careful.
  2. Nokia 6010 Keypad Replacement: adım 2, 2 resimden 1. Nokia 6010 Keypad Replacement: adım 2, 2 resimden 2.
    • Lift the battery near the bottom and pry up.
  3. Nokia 6010 Keypad Replacement, SIM Card: adım 3, 1 resimden 1.
    • With one hand, press the ridged tab near the visible side of the SIM card.
    • Slide the card out with your other hand.
  4. Nokia 6010 Keypad Replacement, Keypad: adım 4, 2 resimden 1. Nokia 6010 Keypad Replacement, Keypad: adım 4, 2 resimden 2.
    • Grip the phone on either the sides, the top, or the bottom.
    • Pull the front case away from the rest of the phone.
    • There are no special tabs to keep it in place so it should wiggle free easily.
  5. Nokia 6010 Keypad Replacement: adım 5, 1 resimden 1.
    • Lift the keypad away from the body of the phone.
    • The keypad is the rubber-backed piece with the number keys.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nicholas Hanne
129 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-45, Regan Winter 2010 Cal Poly, Team 14-45, Regan Winter 2010 üyesi
CPSU-REGAN-W10S14G45
5 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 3,054
