Ana içeriğe geç
Nokia 6010 Microphone Replacement
Neye ihtiyacın var
  1. Nokia 6010 Microphone Replacement, Battery: adım 1, 3 resimden 1. Nokia 6010 Microphone Replacement, Battery: adım 1, 3 resimden 2. Nokia 6010 Microphone Replacement, Battery: adım 1, 3 resimden 3.
    • Press the small tab on the bottom of the back of the phone.
    • Push the back case upward towards the power button. The back case will then pop off.
    • It requires some force, so be careful.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 6010 Microphone Replacement: adım 2, 2 resimden 1. Nokia 6010 Microphone Replacement: adım 2, 2 resimden 2.
    • Lift the battery near the bottom and pry up.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 6010 Microphone Replacement, SIM Card: adım 3, 1 resimden 1.
    • With one hand, press the ridged tab near the visible side of the SIM card.
    • Slide the card out with your other hand.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 6010 Microphone Replacement, Keypad: adım 4, 2 resimden 1. Nokia 6010 Microphone Replacement, Keypad: adım 4, 2 resimden 2.
    • Grip the phone on either the sides, the top, or the bottom.
    • Pull the front case away from the rest of the phone.
    • There are no special tabs to keep it in place so it should wiggle free easily.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia 6010 Microphone Replacement: adım 5, 1 resimden 1.
    • Lift the keypad away from the body of the phone.
    • The keypad is the rubber-backed piece with the number keys.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia 6010 Microphone Replacement, LCD Screen and Speaker: adım 6, 2 resimden 1. Nokia 6010 Microphone Replacement, LCD Screen and Speaker: adım 6, 2 resimden 2.
    • Remove the six screws around the front of the phone body with a T6 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Nokia 6010 Microphone Replacement: adım 7, 3 resimden 1. Nokia 6010 Microphone Replacement: adım 7, 3 resimden 2. Nokia 6010 Microphone Replacement: adım 7, 3 resimden 3.
    • Insert your finger underneath the speaker piece and pry away from the phone body.
    • The plastic layer containing the LCD screen and speaker takes some force to remove.
    • There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
    • The LCD and the speaker are attached to the same piece and must be replaced together.
    FixBot'a Sor
    Yorum Ekle
  8. Nokia 6010 Microphone Replacement, Logic Board: adım 8, 2 resimden 1. Nokia 6010 Microphone Replacement, Logic Board: adım 8, 2 resimden 2.
    • Slide the rubber power button away from the body of the phone.
    • The power button is the rubber piece on the top of the phone.
    FixBot'a Sor
    Yorum Ekle
  9. Nokia 6010 Microphone Replacement: adım 9, 3 resimden 1. Nokia 6010 Microphone Replacement: adım 9, 3 resimden 2. Nokia 6010 Microphone Replacement: adım 9, 3 resimden 3.
    • Insert a finger between the phone body and logic board.
    • The logic board is the green plastic piece with circuitry attached.
    • Pull the board away gently.
    • The board is delicate and contains electronic parts. Be careful while removing it.
    FixBot'a Sor
    Yorum Ekle
  10. Nokia 6010 Microphone Replacement, Microphone: adım 10, 3 resimden 1. Nokia 6010 Microphone Replacement, Microphone: adım 10, 3 resimden 2. Nokia 6010 Microphone Replacement, Microphone: adım 10, 3 resimden 3.
    • Use a spudger or a finger to lift the the microphone off the body of the phone.
    • The microphone is attached to the phone with glue, but removes easily with a spudger.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nicholas Hanne
129 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-45, Regan Winter 2010 Cal Poly, Team 14-45, Regan Winter 2010 üyesi
CPSU-REGAN-W10S14G45
5 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 40
Her zaman: 3,149
