Ana içeriğe geç
Nokia 6030 Keypad Replacement
  1. Nokia 6030 Keypad Replacement, Battery: adım 1, 3 resimden 1. Nokia 6030 Keypad Replacement, Battery: adım 1, 3 resimden 2. Nokia 6030 Keypad Replacement, Battery: adım 1, 3 resimden 3.
    • Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
  2. Nokia 6030 Keypad Replacement: adım 2, 3 resimden 1. Nokia 6030 Keypad Replacement: adım 2, 3 resimden 2. Nokia 6030 Keypad Replacement: adım 2, 3 resimden 3.
    • Use your finger to gently pull the bottom of the battery up by using the slip found at the bottom of the phone.
    • Lift out battery and remove.
  3. Nokia 6030 Keypad Replacement, SIM Card: adım 3, 3 resimden 1. Nokia 6030 Keypad Replacement, SIM Card: adım 3, 3 resimden 2. Nokia 6030 Keypad Replacement, SIM Card: adım 3, 3 resimden 3.
    • Use your finger to lift the metal cage up.
    • Remove SIM card.
  4. Nokia 6030 Keypad Replacement: adım 4, 1 resimden 1.
    • Use your finger to close the metal cage.
  5. Nokia 6030 Keypad Replacement, Front Cover: adım 5, 3 resimden 1. Nokia 6030 Keypad Replacement, Front Cover: adım 5, 3 resimden 2. Nokia 6030 Keypad Replacement, Front Cover: adım 5, 3 resimden 3.
    • Insert your two fingers under the two tabs found at the top of the phone underneath the black casing, then pull the casing up and slide it out slowly.
  6. Nokia 6030 Keypad Replacement: adım 6, 2 resimden 1. Nokia 6030 Keypad Replacement: adım 6, 2 resimden 2.
    • After removing the top cover, turn the phone over so the screen is facing upwards.
  7. Nokia 6030 Keypad Replacement: adım 7, 3 resimden 1. Nokia 6030 Keypad Replacement: adım 7, 3 resimden 2. Nokia 6030 Keypad Replacement: adım 7, 3 resimden 3.
    • Use your fingers to slowly lift the screen back towards the bottom of the phone using the arrows found at the top of the phone.
  8. Nokia 6030 Keypad Replacement, Keypad: adım 8, 2 resimden 1. Nokia 6030 Keypad Replacement, Keypad: adım 8, 2 resimden 2.
    • Gently pull the rubber away from the front screen and the buttons will detach from the plastic case.
  9. Nokia 6030 Keypad Replacement: adım 9, 2 resimden 1. Nokia 6030 Keypad Replacement: adım 9, 2 resimden 2.
    • Remove old keypad and replace it with new keypad.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Spencer Woodworth
316 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 23-63, Johann Spring 2010 Cal Poly, Team 23-63, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S23G63
3 Üyeler
17 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 2,826
