Giriş
Replacing the logic board.
Neye ihtiyacın var
Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
Insert your two fingers under the two tabs found at the top of the phone underneath the black casing, then pull the casing up and slide it out slowly.
Remove the six screws found along the frame of the phone with a T6 Torx screwdriver and put them to the side.
Bir başkası bu kılavuzu tamamladı.
