Ana içeriğe geç
Nokia 6030 Microphone Replacement
Neye ihtiyacın var
  1. Nokia 6030 Microphone Replacement, Battery: adım 1, 3 resimden 1. Nokia 6030 Microphone Replacement, Battery: adım 1, 3 resimden 2. Nokia 6030 Microphone Replacement, Battery: adım 1, 3 resimden 3.
    • Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 6030 Microphone Replacement: adım 2, 3 resimden 1. Nokia 6030 Microphone Replacement: adım 2, 3 resimden 2. Nokia 6030 Microphone Replacement: adım 2, 3 resimden 3.
    • Use your finger to gently pull the bottom of the battery up by using the slip found at the bottom of the phone.
    • Lift out battery and remove.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 6030 Microphone Replacement, SIM Card: adım 3, 3 resimden 1. Nokia 6030 Microphone Replacement, SIM Card: adım 3, 3 resimden 2. Nokia 6030 Microphone Replacement, SIM Card: adım 3, 3 resimden 3.
    • Use your finger to lift the metal cage up.
    • Remove SIM card.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 6030 Microphone Replacement: adım 4, 1 resimden 1.
    • Use your finger to close the metal cage.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia 6030 Microphone Replacement, Front Cover: adım 5, 3 resimden 1. Nokia 6030 Microphone Replacement, Front Cover: adım 5, 3 resimden 2. Nokia 6030 Microphone Replacement, Front Cover: adım 5, 3 resimden 3.
    • Insert your two fingers under the two tabs found at the top of the phone underneath the black casing, then pull the casing up and slide it out slowly.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia 6030 Microphone Replacement: adım 6, 2 resimden 1. Nokia 6030 Microphone Replacement: adım 6, 2 resimden 2.
    • After removing the top cover, turn the phone over so the screen is facing upwards.
    FixBot'a Sor
    Yorum Ekle
  7. Nokia 6030 Microphone Replacement: adım 7, 3 resimden 1. Nokia 6030 Microphone Replacement: adım 7, 3 resimden 2. Nokia 6030 Microphone Replacement: adım 7, 3 resimden 3.
    • Use your fingers to slowly lift the screen back towards the bottom of the phone using the arrows found at the top of the phone.
    FixBot'a Sor
    Yorum Ekle
  8. Nokia 6030 Microphone Replacement, Microphone: adım 8, 3 resimden 1. Nokia 6030 Microphone Replacement, Microphone: adım 8, 3 resimden 2. Nokia 6030 Microphone Replacement, Microphone: adım 8, 3 resimden 3.
    • Remove the six screws with a T-6 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. Nokia 6030 Microphone Replacement: adım 9, 3 resimden 1. Nokia 6030 Microphone Replacement: adım 9, 3 resimden 2. Nokia 6030 Microphone Replacement: adım 9, 3 resimden 3.
    • Lift the logic board and screen from the top.
    • Be careful of loose parts.
    FixBot'a Sor
    Yorum Ekle
  10. Nokia 6030 Microphone Replacement: adım 10, 3 resimden 1. Nokia 6030 Microphone Replacement: adım 10, 3 resimden 2. Nokia 6030 Microphone Replacement: adım 10, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to aid in the removal of the microphone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Spencer Woodworth
346 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 23-63, Johann Spring 2010 Cal Poly, Team 23-63, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S23G63
3 Üyeler
26 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 39
Her zaman: 3,494
