Ana içeriğe geç
Nokia 6086 Keypad Replacement
Neye ihtiyacın var
  1. Nokia 6086 Keypad Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 6086 Keypad Replacement: adım 2, 3 resimden 1. Nokia 6086 Keypad Replacement: adım 2, 3 resimden 2. Nokia 6086 Keypad Replacement: adım 2, 3 resimden 3.
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 6086 Keypad Replacement: adım 3, 3 resimden 1. Nokia 6086 Keypad Replacement: adım 3, 3 resimden 2. Nokia 6086 Keypad Replacement: adım 3, 3 resimden 3.
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 6086 Keypad Replacement, Upper Back Cover: adım 4, 1 resimden 1.
    • Turn the phone so that the back of the phone is facing forward.
    • The picture to the left shows the location of the plastic tabs that attach to the upper cover of the phone.
    • In this picture, the upper cover has already been removed.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia 6086 Keypad Replacement: adım 5, 2 resimden 1. Nokia 6086 Keypad Replacement: adım 5, 2 resimden 2.
    • Place the iPod opening tool under the tabs near the top of the phone.
    • Slide the iPod Opening Tool upwards.
    • This will pop the tabs and release the upper part of the phone.
    • Repeat for the left and the right sides.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia 6086 Keypad Replacement: adım 6, 2 resimden 1. Nokia 6086 Keypad Replacement: adım 6, 2 resimden 2.
    • Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture).
    • Lift the iPod opening tool to pop open the clips.
    • This will release the upper back cover of the phone.
    FixBot'a Sor
    Yorum Ekle
  7. Nokia 6086 Keypad Replacement: adım 7, 3 resimden 1. Nokia 6086 Keypad Replacement: adım 7, 3 resimden 2. Nokia 6086 Keypad Replacement: adım 7, 3 resimden 3.
    • Push upward on the top back cover using two thumbs.
    • This will remove the top back cover from the phone.
    FixBot'a Sor
    Yorum Ekle
  8. Nokia 6086 Keypad Replacement, Base of The Phone: adım 8, 2 resimden 1. Nokia 6086 Keypad Replacement, Base of The Phone: adım 8, 2 resimden 2.
    • Locate the four screws.
    • Remove the screws using a T6 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. Nokia 6086 Keypad Replacement: adım 9, 2 resimden 1. Nokia 6086 Keypad Replacement: adım 9, 2 resimden 2.
    • Turn the phone over.
    • Gently pull apart the phone.
    • Start at the bottom of the phone and pull outward.
    • There are plastic catches on the middle of each side. These should pop free as you pull.
    • Be careful, the phone will separate into two sections.
    FixBot'a Sor
    Yorum Ekle
  10. Nokia 6086 Keypad Replacement: adım 10, 2 resimden 1. Nokia 6086 Keypad Replacement: adım 10, 2 resimden 2.
    • The phone should now be in two different sections.
    • 1) The logic board and the back cover
    • 2) The keypad and the rest of the phone
    FixBot'a Sor
    Yorum Ekle
  11. Nokia 6086 Keypad Replacement, Keypad: adım 11, 1 resimden 1.
    • Place the keypad in view.
    FixBot'a Sor
    Yorum Ekle
  12. Nokia 6086 Keypad Replacement: adım 12, 2 resimden 1. Nokia 6086 Keypad Replacement: adım 12, 2 resimden 2.
    • Remove the keypad from the phone by lifting the keypad off the phone.
    FixBot'a Sor
    Yorum Ekle
  13. Nokia 6086 Keypad Replacement: adım 13, 1 resimden 1.
    • The keypad should be detached.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Caitlin Rahm
78 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 26-30, Regan Spring 2010 Cal Poly, Team 26-30, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G30
4 Üyeler
27 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 50
Her zaman: 1,644
