Ana içeriğe geç
Nokia 6086 Screen Replacement
Neye ihtiyacın var
  1. Nokia 6086 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 6086 Screen Replacement: adım 2, 3 resimden 1. Nokia 6086 Screen Replacement: adım 2, 3 resimden 2. Nokia 6086 Screen Replacement: adım 2, 3 resimden 3.
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 6086 Screen Replacement: adım 3, 3 resimden 1. Nokia 6086 Screen Replacement: adım 3, 3 resimden 2. Nokia 6086 Screen Replacement: adım 3, 3 resimden 3.
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 6086 Screen Replacement, Top Front Cover: adım 4, 1 resimden 1.
    • Close the phone.
    • Face the front cover forward.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia 6086 Screen Replacement: adım 5, 2 resimden 1. Nokia 6086 Screen Replacement: adım 5, 2 resimden 2.
    • Locate the 4.5 mm notch at the top of the phone.
    • Place the iPod opening tool into the opening.
    • Slightly prop up the top section by lifting the tool.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia 6086 Screen Replacement: adım 6, 3 resimden 1. Nokia 6086 Screen Replacement: adım 6, 3 resimden 2. Nokia 6086 Screen Replacement: adım 6, 3 resimden 3.
    • Wedge the iPod opening tool between the top cover and the phone.
    • Gently lift the top cover away from the phone using the iPod opening tool.
    • This unlatches each hook that connects the top cover to the phone.
    • Repeat for both the left and the right sides of the phone.
    • Place the top cover aside once the top cover is completely disconnected from the phone.
    FixBot'a Sor
    Yorum Ekle
  7. Nokia 6086 Screen Replacement, Screen: adım 7, 3 resimden 1. Nokia 6086 Screen Replacement, Screen: adım 7, 3 resimden 2. Nokia 6086 Screen Replacement, Screen: adım 7, 3 resimden 3.
    • Locate the four screws on the phone.
    • The top right screw is located under the black connector piece.
    • To remove the connector piece gently lift it off of its connector.
    • Take the T6 driver and remove the screws.
    FixBot'a Sor
    Yorum Ekle
  8. Nokia 6086 Screen Replacement: adım 8, 1 resimden 1.
    • Carefully lift up the motherboard.
    FixBot'a Sor
    Yorum Ekle
  9. Nokia 6086 Screen Replacement: adım 9, 2 resimden 1. Nokia 6086 Screen Replacement: adım 9, 2 resimden 2.
    • Find the orange slip on the motherboard.
    • Peel back the orange slip to expose the screen.
    FixBot'a Sor
    Yorum Ekle
  10. Nokia 6086 Screen Replacement: adım 10, 3 resimden 1. Nokia 6086 Screen Replacement: adım 10, 3 resimden 2. Nokia 6086 Screen Replacement: adım 10, 3 resimden 3.
    • Place the ipod opening tool under the screen.
    • Remove the damaged screen with the ipod opening tool.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Caitlin Rahm
78 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 26-30, Regan Spring 2010 Cal Poly, Team 26-30, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G30
4 Üyeler
27 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 35
Her zaman: 3,839
