Ana içeriğe geç
Nokia 6102i Inside LCD Display Replacement
Neye ihtiyacın var
  1. Nokia 6102i Inside LCD Display Replacement, Remove Inside Display Screen: adım 1, 3 resimden 1. Nokia 6102i Inside LCD Display Replacement, Remove Inside Display Screen: adım 1, 3 resimden 2. Nokia 6102i Inside LCD Display Replacement, Remove Inside Display Screen: adım 1, 3 resimden 3.
    • This step does not require much force.
    • Use the plastic opening tool to pry between the seam of the black phone cover which is located at the base of the screen.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 6102i Inside LCD Display Replacement, Remove Phone Case Screws.: adım 2, 2 resimden 1. Nokia 6102i Inside LCD Display Replacement, Remove Phone Case Screws.: adım 2, 2 resimden 2.
    • Have a container ready to keep track of small parts.
    • Use the t6 screwdriver to remove the two visible screws that are immediately below the screen.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 6102i Inside LCD Display Replacement, Remove silver and black phone case: adım 3, 2 resimden 1. Nokia 6102i Inside LCD Display Replacement, Remove silver and black phone case: adım 3, 2 resimden 2.
    • Keep the phone closed, and slide the Ipod tool between the the silver and black phone case. Use the tool to slide all the way around the case to release the catches.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 6102i Inside LCD Display Replacement, Unplug and Remove Circuit Board: adım 4, 2 resimden 1. Nokia 6102i Inside LCD Display Replacement, Unplug and Remove Circuit Board: adım 4, 2 resimden 2.
    • Pull out the circuit board, which will remove it completely from the case
    FixBot'a Sor
    Yorum Ekle
  5. Nokia 6102i Inside LCD Display Replacement, Remove Display Screen: adım 5, 3 resimden 1. Nokia 6102i Inside LCD Display Replacement, Remove Display Screen: adım 5, 3 resimden 2. Nokia 6102i Inside LCD Display Replacement, Remove Display Screen: adım 5, 3 resimden 3.
    • If the metal case is not already free, simultaneously release the metal tabs on both sides of the metal casing to remove the display screen.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia 6102i Inside LCD Display Replacement, Disconnect Interior Display Screen from circuit board.: adım 6, 2 resimden 1. Nokia 6102i Inside LCD Display Replacement, Disconnect Interior Display Screen from circuit board.: adım 6, 2 resimden 2.
    • Be gentle when pulling off the display screen. If pulled too hard, the orange connecting ribbon will rip.
    • Lift off the display screen and disconnect it from the circuit board.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Alex Graebe
10 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 23-78, Johann Spring 2010 Cal Poly, Team 23-78, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S23G78
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 4,465
