Ana içeriğe geç
Nokia 6102i motherboard replacement
Neye ihtiyacın var
  1. Nokia 6102i motherboard replacement, Battery: adım 1, 3 resimden 1. Nokia 6102i motherboard replacement, Battery: adım 1, 3 resimden 2. Nokia 6102i motherboard replacement, Battery: adım 1, 3 resimden 3.
    • Press and hold the button at the bottom of the back side of the phone while sliding the back plate down to remove the back cover.
    • Note: Images on the right side may be hovered over to reveal larger versions.
  2. Nokia 6102i motherboard replacement: adım 2, 1 resimden 1.
    • Lift up the battery from the inside of the phone.
    • Make sure to lift up from the bottom of the battery as shown.
  3. Nokia 6102i motherboard replacement, Logic Board: adım 3, 2 resimden 1. Nokia 6102i motherboard replacement, Logic Board: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    T6 Torx Screwdriver
    $9.99
    Satın Al
    • Using a .208 head T-6 Screwdriver remove the two screws at the bottom of the battery cavity.
  4. Nokia 6102i motherboard replacement: adım 4, 2 resimden 1. Nokia 6102i motherboard replacement: adım 4, 2 resimden 2.
    • Use a plastic opening tool to remove the silver cover over the antenna.
    • The covering may not pop right off. It may require some prying in different locations around the top covering.
  5. Nokia 6102i motherboard replacement: adım 5, 2 resimden 1. Nokia 6102i motherboard replacement: adım 5, 2 resimden 2.
    • Remove the two newly revealed .208 inch screws at the top using a T-6 screwdriver.
  6. Nokia 6102i motherboard replacement: adım 6, 2 resimden 1. Nokia 6102i motherboard replacement: adım 6, 2 resimden 2.
    • WARNING: Use extreme caution when removing and handling the logic board as it is very fragile.
    • With caution, use a plastic prier to separate the back silver casing from the front of the phone. This may require force.
    • Disconnect the logic board from the small orange chip.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alex Graebe
1 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 23-78, Johann Spring 2010 Cal Poly, Team 23-78, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S23G78
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 2,633
