Giriş
The back cover of the phone will have to be removed first. No tools are required.
  1. Turn the phone so it is face down (keypad side is down).
    • Turn the phone so it is face down (keypad side is down).
  2. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Press and hold the button located at the bottom of the phone. Slide the back of the phone downwards and away from the main body. Remove the backing and place it to the side.
    • Press and hold the button located at the bottom of the phone.
    • Slide the back of the phone downwards and away from the main body.
    • Remove the backing and place it to the side.
  4. Locate indentation from which battery can be removed. Place finger in indentation and lift battery up from phone's body. Remove battery from phone's body.
    • Locate indentation from which battery can be removed.
    • Place finger in indentation and lift battery up from phone's body.
    • Remove battery from phone's body.
Sonuç
To replace the battery, simply put a new battery in the back of the phone, and replace the back cover.
Reid Polstra
1 İtibar
7 adet Kılavuz yazıldı
Takım
Clemson, Team 15-5, Benson Fall 2012 Clemson, Team 15-5, Benson Fall 2012 üyesi
CLEM-BENSON-F12S15G5
3 Üyeler
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 3
Her zaman: 925
