Giriş
The back cover and the battery have to be removed before the SimCard can be reached. No tools are required.
Aletler
Hiçbir alete gerek yok.
Parçalar
Hiçbir parçaya gerek yok.
  1. Turn the phone so it is face down (keypad side is down).
    • Turn the phone so it is face down (keypad side is down).
  2. Press and hold the button located at the bottom of the phone. Slide the back of the phone downwards and away from the main body. Remove the backing and place it to the side.
    • Press and hold the button located at the bottom of the phone.
    • Slide the back of the phone downwards and away from the main body.
    • Remove the backing and place it to the side.
  3. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Locate indentation from which battery can be removed. Place finger in indentation and lift battery up from phone's body. Remove battery from phone's body.
    • Locate indentation from which battery can be removed.
    • Place finger in indentation and lift battery up from phone's body.
    • Remove battery from phone's body.
  5. Push the SimCard towards the bottom of the phone.
    • Push the SimCard towards the bottom of the phone.
  6. Slide finger underneath top of SimCard. Lift up the SimCard and rotate the top of the SimCard so it moves toward the bottom of the phone.
    • Slide finger underneath top of SimCard.
    • Lift up the SimCard and rotate the top of the SimCard so it moves toward the bottom of the phone.
  7. Pull up on the SimCard and remove it from the back of the phone. Place the SimCard to the side.
    • Pull up on the SimCard and remove it from the back of the phone.
    • Place the SimCard to the side.
Sonuç
To insert a new SimCard, simply push the card in as shown in step 6, and snap it in place.
Reid Polstra
1 İtibar
7 adet Kılavuz yazıldı
Takım
Clemson, Team 15-5, Benson Fall 2012 Clemson, Team 15-5, Benson Fall 2012 üyesi
CLEM-BENSON-F12S15G5
3 Üyeler
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 2
Her zaman: 615
