Ana içeriğe geç
Nokia 6236i Front Casing Replacement
Neye ihtiyacın var
  1. Nokia 6236i Front Casing Replacement, Battery: adım 1, 2 resimden 1. Nokia 6236i Front Casing Replacement, Battery: adım 1, 2 resimden 2.
    • Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
    • Lift the battery case off of the phone.
  2. Nokia 6236i Front Casing Replacement: adım 2, 3 resimden 1. Nokia 6236i Front Casing Replacement: adım 2, 3 resimden 2. Nokia 6236i Front Casing Replacement: adım 2, 3 resimden 3.
    • Use your thumb to get underneath the battery and pull up and out from the bottom of the battery tray.
    • The battery should lift out with minimal resistance.
  3. Nokia 6236i Front Casing Replacement, SIM Card: adım 3, 3 resimden 1. Nokia 6236i Front Casing Replacement, SIM Card: adım 3, 3 resimden 2. Nokia 6236i Front Casing Replacement, SIM Card: adım 3, 3 resimden 3.
    • Once the battery is removed, pull the tab of the metal sim card cover, and lift it up.
    • The sim card is underneath and can now be removed.
  4. Nokia 6236i Front Casing Replacement, Front Casing: adım 4, 3 resimden 1. Nokia 6236i Front Casing Replacement, Front Casing: adım 4, 3 resimden 2. Nokia 6236i Front Casing Replacement, Front Casing: adım 4, 3 resimden 3.
    • Insert a spudger into the indention on the bottom right side of the device.
    • Slide the spudger upward to a second indention at the top of the phone.
    • The front casing will detach from the phone.
Sonuç
The front casing will be detached without causing damage to the case or phone model.
For reassembly, complete the listed steps in reverse.
Erik Lindahl
63 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-46, Garner Spring 2010 Cal Poly, Team 10-46, Garner Spring 2010 üyesi
CPSU-GARNER-S10S10G46
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 14
Her zaman: 1,867
