Ana içeriğe geç
Nokia 6310i Antenna Replacement
Neye ihtiyacın var
  1. Nokia 6310i Antenna Replacement, Battery: adım 1, 2 resimden 1. Nokia 6310i Antenna Replacement, Battery: adım 1, 2 resimden 2.
    • Press and hold the battery release button and slide the battery away from the Nokia logo
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 6310i Antenna Replacement, SIM card: adım 2, 3 resimden 1. Nokia 6310i Antenna Replacement, SIM card: adım 2, 3 resimden 2. Nokia 6310i Antenna Replacement, SIM card: adım 2, 3 resimden 3.
    • Slide the SIM card lock away from the SIM card.
    • The SIM card pops out. Remove the SIM card.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 6310i Antenna Replacement, Back Cover: adım 3, 1 resimden 1.
    • Unscrew and remove the four T6 Torx screws.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 6310i Antenna Replacement: adım 4, 3 resimden 1. Nokia 6310i Antenna Replacement: adım 4, 3 resimden 2. Nokia 6310i Antenna Replacement: adım 4, 3 resimden 3.
    • Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia 6310i Antenna Replacement: adım 5, 3 resimden 1. Nokia 6310i Antenna Replacement: adım 5, 3 resimden 2. Nokia 6310i Antenna Replacement: adım 5, 3 resimden 3.
    • Use the plastic opening tool to separate the top part of the backplate.
    • The plastic clips at the top require slightly more force to separate.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia 6310i Antenna Replacement, Antenna: adım 6, 2 resimden 1. Nokia 6310i Antenna Replacement, Antenna: adım 6, 2 resimden 2.
    • Remove the screw holding the antenna to the circuit board.
    • Carefully lift off the antenna from the circuit board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Wilson Tam
77 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-41, Forte Fall 2010 Cal Poly, Team 14-41, Forte Fall 2010 üyesi
CPSU-FORTE-F10S14G41
5 Üyeler
30 adet Kılavuz yazıldı
2Kılavuz Yorumları
Thanks for a nice and helpful instruction.
The rubber power-on button had broken down so I just removed the damaged parts. Now using a toothpick to push the microswitch directly.
Only using the phone indoors for nostalgic reasons, playing Snake :-)
Brgrds Ove
ove.tandberg - Yanıt Paylaş
Thanks for antenna help
I have had about three 6310i’s and the on/off button was the failure problem in all three.
Andrew Richards - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 8,866
