Ana içeriğe geç
Nokia 6310i Back Cover Replacement
Neye ihtiyacın var
  1. Nokia 6310i Back Cover Replacement, Battery: adım 1, 2 resimden 1. Nokia 6310i Back Cover Replacement, Battery: adım 1, 2 resimden 2.
    • Press and hold the battery release button and slide the battery away from the Nokia logo
  2. Nokia 6310i Back Cover Replacement, SIM card: adım 2, 3 resimden 1. Nokia 6310i Back Cover Replacement, SIM card: adım 2, 3 resimden 2. Nokia 6310i Back Cover Replacement, SIM card: adım 2, 3 resimden 3.
    • Slide the SIM card lock away from the SIM card.
    • The SIM card pops out. Remove the SIM card.
  3. Nokia 6310i Back Cover Replacement, Back Cover: adım 3, 1 resimden 1.
    • Unscrew and remove the four T6 Torx screws.
  4. Nokia 6310i Back Cover Replacement: adım 4, 3 resimden 1. Nokia 6310i Back Cover Replacement: adım 4, 3 resimden 2. Nokia 6310i Back Cover Replacement: adım 4, 3 resimden 3.
    • Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
  5. Nokia 6310i Back Cover Replacement: adım 5, 3 resimden 1. Nokia 6310i Back Cover Replacement: adım 5, 3 resimden 2. Nokia 6310i Back Cover Replacement: adım 5, 3 resimden 3.
    • Use the plastic opening tool to separate the top part of the backplate.
    • The plastic clips at the top require slightly more force to separate.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mustafa
156 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-41, Forte Fall 2010 Cal Poly, Team 14-41, Forte Fall 2010 üyesi
CPSU-FORTE-F10S14G41
5 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 4,459
