Ana içeriğe geç
Nokia 6310i Keypad Replacement
Neye ihtiyacın var
  1. Nokia 6310i Keypad Replacement, Battery: adım 1, 2 resimden 1. Nokia 6310i Keypad Replacement, Battery: adım 1, 2 resimden 2.
    • Press and hold the battery release button and slide the battery away from the Nokia logo
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 6310i Keypad Replacement, SIM card: adım 2, 3 resimden 1. Nokia 6310i Keypad Replacement, SIM card: adım 2, 3 resimden 2. Nokia 6310i Keypad Replacement, SIM card: adım 2, 3 resimden 3.
    • Slide the SIM card lock away from the SIM card.
    • The SIM card pops out. Remove the SIM card.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 6310i Keypad Replacement, Back Cover: adım 3, 1 resimden 1.
    • Unscrew and remove the four T6 Torx screws.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 6310i Keypad Replacement: adım 4, 3 resimden 1. Nokia 6310i Keypad Replacement: adım 4, 3 resimden 2. Nokia 6310i Keypad Replacement: adım 4, 3 resimden 3.
    • Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia 6310i Keypad Replacement: adım 5, 3 resimden 1. Nokia 6310i Keypad Replacement: adım 5, 3 resimden 2. Nokia 6310i Keypad Replacement: adım 5, 3 resimden 3.
    • Use the plastic opening tool to separate the top part of the backplate.
    • The plastic clips at the top require slightly more force to separate.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia 6310i Keypad Replacement, Antenna: adım 6, 2 resimden 1. Nokia 6310i Keypad Replacement, Antenna: adım 6, 2 resimden 2.
    • Remove the screw holding the antenna to the circuit board.
    • Carefully lift off the antenna from the circuit board.
    FixBot'a Sor
    Yorum Ekle
  7. Nokia 6310i Keypad Replacement, Motherboard: adım 7, 1 resimden 1.
    • Lift off the motherboard from the faceplate.
    FixBot'a Sor
    Yorum Ekle
  8. Nokia 6310i Keypad Replacement, Keypad: adım 8, 2 resimden 1. Nokia 6310i Keypad Replacement, Keypad: adım 8, 2 resimden 2.
    • Remove the plastic keypad from the faceplate.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ka Siu
84 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-41, Forte Fall 2010 Cal Poly, Team 14-41, Forte Fall 2010 üyesi
CPSU-FORTE-F10S14G41
5 Üyeler
30 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 6,063
