Ana içeriğe geç
Nokia 6310i Keypad Replacement
Neye ihtiyacın var
  1. Nokia 6310i Keypad Replacement, Battery: adım 1, 2 resimden 1. Nokia 6310i Keypad Replacement, Battery: adım 1, 2 resimden 2.
    • Press and hold the battery release button and slide the battery away from the Nokia logo
  2. Nokia 6310i Keypad Replacement, SIM card: adım 2, 3 resimden 1. Nokia 6310i Keypad Replacement, SIM card: adım 2, 3 resimden 2. Nokia 6310i Keypad Replacement, SIM card: adım 2, 3 resimden 3.
    • Slide the SIM card lock away from the SIM card.
    • The SIM card pops out. Remove the SIM card.
  3. Nokia 6310i Keypad Replacement, Back Cover: adım 3, 1 resimden 1.
    • Unscrew and remove the four T6 Torx screws.
  4. Nokia 6310i Keypad Replacement: adım 4, 3 resimden 1. Nokia 6310i Keypad Replacement: adım 4, 3 resimden 2. Nokia 6310i Keypad Replacement: adım 4, 3 resimden 3.
    • Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
  5. Nokia 6310i Keypad Replacement: adım 5, 3 resimden 1. Nokia 6310i Keypad Replacement: adım 5, 3 resimden 2. Nokia 6310i Keypad Replacement: adım 5, 3 resimden 3.
    • Use the plastic opening tool to separate the top part of the backplate.
    • The plastic clips at the top require slightly more force to separate.
  6. Nokia 6310i Keypad Replacement, Antenna: adım 6, 2 resimden 1. Nokia 6310i Keypad Replacement, Antenna: adım 6, 2 resimden 2.
    • Remove the screw holding the antenna to the circuit board.
    • Carefully lift off the antenna from the circuit board.
  7. Nokia 6310i Keypad Replacement, Motherboard: adım 7, 1 resimden 1.
    • Lift off the motherboard from the faceplate.
  8. Nokia 6310i Keypad Replacement, Keypad: adım 8, 2 resimden 1. Nokia 6310i Keypad Replacement, Keypad: adım 8, 2 resimden 2.
    • Remove the plastic keypad from the faceplate.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ka Siu
78 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-41, Forte Fall 2010 Cal Poly, Team 14-41, Forte Fall 2010 üyesi
CPSU-FORTE-F10S14G41
5 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 5,595
