Ana içeriğe geç
Nokia 6310i Motherboard Replacement
Neye ihtiyacın var
  1. Nokia 6310i Motherboard Replacement, Battery: adım 1, 2 resimden 1. Nokia 6310i Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Press and hold the battery release button and slide the battery away from the Nokia logo
  2. Nokia 6310i Motherboard Replacement, SIM card: adım 2, 3 resimden 1. Nokia 6310i Motherboard Replacement, SIM card: adım 2, 3 resimden 2. Nokia 6310i Motherboard Replacement, SIM card: adım 2, 3 resimden 3.
    • Slide the SIM card lock away from the SIM card.
    • The SIM card pops out. Remove the SIM card.
  3. Nokia 6310i Motherboard Replacement, Back Cover: adım 3, 1 resimden 1.
    • Unscrew and remove the four T6 Torx screws.
    Needs updating with a picture with no SIM card.
    Mustafa - Yanıt
    A comment for anyone wanting to clean the metal contacts to improve keypad response, make sure you spray iso alcohol onto a lint free cloth and wipe the contacts, not onto the device itself and definitely not onto the LCD screen, as it can leave a marl on the screen. Luckily it evaporated eventually but only after 48hrs...
    John - Yanıt
  4. Nokia 6310i Motherboard Replacement: adım 4, 3 resimden 1. Nokia 6310i Motherboard Replacement: adım 4, 3 resimden 2. Nokia 6310i Motherboard Replacement: adım 4, 3 resimden 3.
    • Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
  5. Nokia 6310i Motherboard Replacement: adım 5, 3 resimden 1. Nokia 6310i Motherboard Replacement: adım 5, 3 resimden 2. Nokia 6310i Motherboard Replacement: adım 5, 3 resimden 3.
    • Use the plastic opening tool to separate the top part of the backplate.
    • The plastic clips at the top require slightly more force to separate.
  6. Nokia 6310i Motherboard Replacement, Antenna: adım 6, 2 resimden 1. Nokia 6310i Motherboard Replacement, Antenna: adım 6, 2 resimden 2.
    • Remove the screw holding the antenna to the circuit board.
    • Carefully lift off the antenna from the circuit board.
  7. Nokia 6310i Motherboard Replacement, Motherboard: adım 7, 1 resimden 1.
    • Lift off the motherboard from the faceplate.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mustafa
156 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-41, Forte Fall 2010 Cal Poly, Team 14-41, Forte Fall 2010 üyesi
CPSU-FORTE-F10S14G41
5 Üyeler
16 adet Kılavuz yazıldı
Bir Yorum
This includes removing the antenna, since it's just one screw.
The antenna guide talks about "replacing the antenna."
Mustafa - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 7,095
