Ana içeriğe geç
Nokia 6350-1b Battery Replacement
Neye ihtiyacın var
  1. Nokia 6350-1b Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the back cover of the phone by sliding it downwards.
    • This will be a thin panel that has three stripes to provide better grip.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 6350-1b Battery Replacement: adım 2, 1 resimden 1.
    • Caution: When you slide the panel downwards, it will immediately come loose.
    • Remove the BP-6MT battery. There should be an indent showing where you will lift.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 6350-1b Battery Replacement: adım 3, 1 resimden 1.
    • Once you have removed the old battery, you can begin to install the new battery.
    • Line up the gold indentations in the upper left corner of the battery with the three gold indentations in the upper left hand corner of the empty battery space.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 6350-1b Battery Replacement: adım 4, 1 resimden 1.
    • Ensure that when you have lined up the battery, you are able to seamlessly insert into phone.
    • Note: If it does not slide seamlessly, it is not being inserted correctly
    FixBot'a Sor
    Yorum Ekle
  5. Nokia 6350-1b Battery Replacement: adım 5, 1 resimden 1.
    • After the battery has clicked in, you need to reinstall the back panel of the phone.
    • Line the back panel up with the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia 6350-1b Battery Replacement: adım 6, 1 resimden 1.
    • Line up the back panel starting from the bottom.
    • Once lined and pressed down, slide upward. You should be able to feel and hear it click back into place.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Anna
25 İtibar
2 adet Kılavuz yazıldı
Ekip
SUNY Cortland, Team 1-2, Getto Spring 2012 SUNY Cortland, Team 1-2, Getto Spring 2012 üyesi
SUNYCORT-GETTO-S12S1G2
2 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 1,725
