Ana içeriğe geç
Nokia 6350-1b Display Screen Replacement
Neye ihtiyacın var
  1. Nokia 6350-1b Display Screen Replacement, Display Screen: adım 1, 2 resimden 1. Nokia 6350-1b Display Screen Replacement, Display Screen: adım 1, 2 resimden 2.
    • Using a plastic pry, get between the plastic frame and the rest of the phone.
    • Move the plastic pry along the frame unlocking all of the locks that keep the frame in place.
    • Remove the plastic frame.
    • Be careful not to pry too hard, doing so could crack the plastic frame.
  2. Nokia 6350-1b Display Screen Replacement: adım 2, 1 resimden 1.
    • Using a T-5 screw driver, unscrew the screws on the four corners of the phone.
    • Using a pry, get between the screen cover and the rest of the phone.
    • Move along this layer unlocking the various locks that keep it in place.
    • Carefully remove the screen cover to reveal the logic board.
    • Keep track of the four small screws. They will be needed to put the phone back together.
  3. Nokia 6350-1b Display Screen Replacement: adım 3, 1 resimden 1.
    • Disconnect the flex cable from the logic board.
    • Disconnect the LCD display screen.
    • Remove the LCD display screen from the rest of the device.
  4. Nokia 6350-1b Display Screen Replacement: adım 4, 1 resimden 1.
    • Connect the new LCD display screen to the phone.
    • Reconnect the Logic Board to the flex cable.
  5. Nokia 6350-1b Display Screen Replacement: adım 5, 1 resimden 1.
    • Using the T-5 screwdriver, screw the four screws back into the phone.
  6. Nokia 6350-1b Display Screen Replacement: adım 6, 1 resimden 1.
    • Place the cover back on the device so that it is in the correct position to be reinstalled.
    • Press gently on the cover so that it snaps back into place.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Anna
21 İtibar
2 adet Kılavuz yazıldı
Ekip
SUNY Cortland, Team 1-2, Getto Spring 2012 SUNY Cortland, Team 1-2, Getto Spring 2012 üyesi
SUNYCORT-GETTO-S12S1G2
2 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Hi
Thanks for putting these together. I have a flip phone 6350 and I love it. Every time one stops functioning I get another one used. But I often have problems with the charging ports. The connection gets wonky and only works when I move the plug around in the socket of the phone. Can these be easily replaced? fixed? I even tried using a universal charger and charged the batteries in that, but then the battery connections stopped working.
thanks!
Annemarie
Annemarie Heineman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 1,850
