Ana içeriğe geç
Nokia 6350-1b Logic board Replacement
Neye ihtiyacın var
  1. Nokia 6350-1b Logic board Replacement, Taking off the plastic frame: adım 1, 2 resimden 1. Nokia 6350-1b Logic board Replacement, Taking off the plastic frame: adım 1, 2 resimden 2.
    • Using a plastic pry, get between the plastic frame and the rest of the phone.
    • Move it along the frame unlocking the locks that keep the frame in place.
    • Remove the plastic frame.
    • Be careful not to pry to hard and crack the plastic frame.
  2. Nokia 6350-1b Logic board Replacement, Removing the screen cover: adım 2, 3 resimden 1. Nokia 6350-1b Logic board Replacement, Removing the screen cover: adım 2, 3 resimden 2. Nokia 6350-1b Logic board Replacement, Removing the screen cover: adım 2, 3 resimden 3.
    • Using a T-5 screw driver, unscrew the screws on the four corners of the phone.
    • Using a pry, get between the screen cover and the rest of the phone.
    • Move alone this layer unlocking the various locks that keep it in place.
    • Carefully remove the screen cover to reveal the logic board.
    • Keep track of the four small screws. They will be needed to put the phone back together.
  3. Nokia 6350-1b Logic board Replacement, Removing broken logic board: adım 3, 3 resimden 1. Nokia 6350-1b Logic board Replacement, Removing broken logic board: adım 3, 3 resimden 2. Nokia 6350-1b Logic board Replacement, Removing broken logic board: adım 3, 3 resimden 3.
    • Disconnect the flex cable from the logic board.
    • Disconnect the camera from the logic board.
    • Disconnect the LCD display screen.
    • Disconnect the LCD phone screen.
    • Carefully remove the broken logic board by freeing it from the various locks holding it in place.
    • Be careful not to touch either of the screens. You can leave finger prints and damage the screens.
  4. Nokia 6350-1b Logic board Replacement, Replacing Logic Board: adım 4, 2 resimden 1. Nokia 6350-1b Logic board Replacement, Replacing Logic Board: adım 4, 2 resimden 2.
    • Take the new logic board and connect all the parts you just disconnected to their correct locations.
  5. Nokia 6350-1b Logic board Replacement: adım 5, 2 resimden 1. Nokia 6350-1b Logic board Replacement: adım 5, 2 resimden 2.
    • Place the cover so that it is in the correct position to be re-installed.
    • Press gently on the cover so that it snaps back into place.
Sonuç
Adrianna
35 İtibar
2 adet Kılavuz yazıldı
Ekip
SUNY Cortland, Team 1-2, Getto Spring 2012 SUNY Cortland, Team 1-2, Getto Spring 2012 üyesi
SUNYCORT-GETTO-S12S1G2
2 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 1,576
