Ana içeriğe geç
Nokia 6560 Speaker Replacement
Neye ihtiyacın var
  1. Nokia 6560 Speaker Replacement, Battery: adım 1, 2 resimden 1. Nokia 6560 Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone.
    • Lift off your cell phone's back cover.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 6560 Speaker Replacement: adım 2, 2 resimden 1. Nokia 6560 Speaker Replacement: adım 2, 2 resimden 2.
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove the battery from your cell phone.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 6560 Speaker Replacement, Keypad: adım 3, 2 resimden 1. Nokia 6560 Speaker Replacement, Keypad: adım 3, 2 resimden 2.
    • Open the front cover of your cell phone with the plastic opening tool or finger nail.
    • Lift the cover upwards, starting from the bottom below the keypad.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 6560 Speaker Replacement: adım 4, 2 resimden 1. Nokia 6560 Speaker Replacement: adım 4, 2 resimden 2.
    • Lift the keypad off of the keyboard as it is not attached to the phone anymore.
    • If you want to clean your keyboard do not use chemical cleaners or too much water, instead, use a damp cloth.
    • It may be tricky to get the keypad in the right position while closing the front cover for the reassembly. Ensure they are aligned properly before closing the front cover!
    FixBot'a Sor
    Yorum Ekle
  5. Nokia 6560 Speaker Replacement, Keyboard: adım 5, 1 resimden 1.
    • Unscrew the six T6 torx screws which attach the frame to the cell phone case.
    • Be careful not to scratch your display with the screw driver.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia 6560 Speaker Replacement: adım 6, 1 resimden 1.
    • Lift the frame off of your cell phone.
    FixBot'a Sor
    Yorum Ekle
  7. Nokia 6560 Speaker Replacement: adım 7, 1 resimden 1.
    • Lift the keyboard out of the plastic frame.
    FixBot'a Sor
    Yorum Ekle
  8. Nokia 6560 Speaker Replacement, Display: adım 8, 2 resimden 1. Nokia 6560 Speaker Replacement, Display: adım 8, 2 resimden 2.
    • Use the plastic opening tool to unmount the thin metal frame at the tab connections. You must do this on both sides.
    • Lift the thin metal frame off of the plastic frame.
    • Pay attention while lifting the frame off because it can easily be bent.
    FixBot'a Sor
    Yorum Ekle
  9. Nokia 6560 Speaker Replacement: adım 9, 3 resimden 1. Nokia 6560 Speaker Replacement: adım 9, 3 resimden 2. Nokia 6560 Speaker Replacement: adım 9, 3 resimden 3.
    • Pull the sides of the plastic frame apart in order to loosen the display.
    • Take the display out of the plastic frame.
    FixBot'a Sor
    Yorum Ekle
  10. Nokia 6560 Speaker Replacement, Speaker: adım 10, 2 resimden 1. Nokia 6560 Speaker Replacement, Speaker: adım 10, 2 resimden 2.
    • Now you have the bare plastic frame that holds the speaker.
    • The microphone is held at the bottom of this frame.
    • Neither the speaker nor the microphone can be repaired. You must replace the whole frame.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Nathan Whitacre
21 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-17, Maness Winter 2010 Cal Poly, Team 3-17, Maness Winter 2010 üyesi
CPSU-MANESS-W10S3G17
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 37
Her zaman: 3,041
