Ana içeriğe geç
Nokia 6560 keypad replacement or cleaning
Neye ihtiyacın var
  1. Nokia 6560 keypad replacement or cleaning, Battery: adım 1, 2 resimden 1. Nokia 6560 keypad replacement or cleaning, Battery: adım 1, 2 resimden 2.
    • Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone.
    • Lift off your cell phone's back cover.
  2. Nokia 6560 keypad replacement or cleaning: adım 2, 2 resimden 1. Nokia 6560 keypad replacement or cleaning: adım 2, 2 resimden 2.
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove the battery from your cell phone.
  3. Nokia 6560 keypad replacement or cleaning, Keypad: adım 3, 2 resimden 1. Nokia 6560 keypad replacement or cleaning, Keypad: adım 3, 2 resimden 2.
    • Open the front cover of your cell phone with the plastic opening tool or finger nail.
    • Lift the cover upwards, starting from the bottom below the keypad.
  4. Nokia 6560 keypad replacement or cleaning: adım 4, 2 resimden 1. Nokia 6560 keypad replacement or cleaning: adım 4, 2 resimden 2.
    • Lift the keypad off of the keyboard as it is not attached to the phone anymore.
    • If you want to clean your keyboard do not use chemical cleaners or too much water, instead, use a damp cloth.
    • It may be tricky to get the keypad in the right position while closing the front cover for the reassembly. Ensure they are aligned properly before closing the front cover!
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Tim Bergmann
35 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-17, Maness Winter 2010 Cal Poly, Team 3-17, Maness Winter 2010 üyesi
CPSU-MANESS-W10S3G17
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 2,228
