Ana içeriğe geç
Nokia 6590i Speaker Replacement
Neye ihtiyacın var
  1. Nokia 6590i Speaker Replacement, Battery: adım 1, 2 resimden 1. Nokia 6590i Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Press the button on the bottom of the rear cover.
    • Keep the button pressed while pulling the cover downward to remove the back cover.
    • Lift the cover off.
  2. Nokia 6590i Speaker Replacement: adım 2, 1 resimden 1.
    • To remove the battery, push it down from the top and pull it out.
  3. Nokia 6590i Speaker Replacement, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: adım 3, 1 resimden 1.
    • Grip the front cover from the bottom.
  4. Nokia 6590i Speaker Replacement: adım 4, 1 resimden 1.
    • Lift the front cover off.
  5. Nokia 6590i Speaker Replacement: adım 5, 1 resimden 1.
    • Remove the six screws using a T6 torx screwdriver.
  6. Nokia 6590i Speaker Replacement: adım 6, 1 resimden 1.
    • Insert spudger along edge of assembly and gently lift assembly away from case
  7. Nokia 6590i Speaker Replacement: adım 7, 1 resimden 1.
    • Remove assembly from phone
  8. Nokia 6590i Speaker Replacement, Speaker: adım 8, 1 resimden 1.
    • Flip assembly over
  9. Nokia 6590i Speaker Replacement: adım 9, 1 resimden 1.
    • Locate speaker on the back of the assembly.
  10. Nokia 6590i Speaker Replacement: adım 10, 1 resimden 1.
    • Insert spudger under upper left side of speaker and gently lift to remove
  11. Nokia 6590i Speaker Replacement: adım 11, 1 resimden 1.
    • Remove speaker.
Sonuç
Colby Leslie
1 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-3, Maness Fall 2010 Cal Poly, Team 22-3, Maness Fall 2010 üyesi
CPSU-MANESS-F10S22G3
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 763
