Ana içeriğe geç
Nokia 6590i Vibrator Replacement
Neye ihtiyacın var
  1. Nokia 6590i Vibrator Replacement, Battery: adım 1, 2 resimden 1. Nokia 6590i Vibrator Replacement, Battery: adım 1, 2 resimden 2.
    • Press the button on the bottom of the rear cover.
    • Keep the button pressed while pulling the cover downward to remove the back cover.
    • Lift the cover off.
  2. Nokia 6590i Vibrator Replacement: adım 2, 1 resimden 1.
    • To remove the battery, push it down from the top and pull it out.
  3. Nokia 6590i Vibrator Replacement, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: adım 3, 1 resimden 1.
    • Grip the front cover from the bottom.
  4. Nokia 6590i Vibrator Replacement: adım 4, 1 resimden 1.
    • Lift the front cover off.
  5. Nokia 6590i Vibrator Replacement: adım 5, 1 resimden 1.
    • Remove the six screws using a T6 torx screwdriver.
  6. Nokia 6590i Vibrator Replacement: adım 6, 1 resimden 1.
    • Insert spudger along edge of assembly and gently lift assembly away from case
  7. Nokia 6590i Vibrator Replacement: adım 7, 1 resimden 1.
    • Remove assembly from phone
  8. Nokia 6590i Vibrator Replacement, Logic Board: adım 8, 1 resimden 1.
    • The logic board now sits on top of the phone.
  9. Nokia 6590i Vibrator Replacement: adım 9, 1 resimden 1.
    • Lift the logic board out of the phone.
  10. Nokia 6590i Vibrator Replacement, Battery Charger Connector: adım 10, 1 resimden 1.
    • Locate battery charger connector
  11. Nokia 6590i Vibrator Replacement: adım 11, 1 resimden 1.
    • Grasp top and bottom of battery charger connector on the left side
  12. Nokia 6590i Vibrator Replacement: adım 12, 1 resimden 1.
    • Lift out the battery charger connector
  13. Nokia 6590i Vibrator Replacement, Vibrator: adım 13, 1 resimden 1.
    • Grasp vibrator which protrudes from the battery charger connector
  14. Nokia 6590i Vibrator Replacement: adım 14, 1 resimden 1.
    • Lift the vibrator out of the battery charger connector.
Sonuç
Colby Leslie
1 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-3, Maness Fall 2010 Cal Poly, Team 22-3, Maness Fall 2010 üyesi
CPSU-MANESS-F10S22G3
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,112
