Ana içeriğe geç
Nokia 8260 Antenna Replacement
Neye ihtiyacın var
  1. Nokia 8260 Antenna Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the cell phone.
  2. Nokia 8260 Antenna Replacement: adım 2, 1 resimden 1.
    • Press down on the round button on the back cover of the phone.
  3. Nokia 8260 Antenna Replacement: adım 3, 1 resimden 1.
    • Slide the back cover down while still pressing the button.
  4. Nokia 8260 Antenna Replacement: adım 4, 1 resimden 1.
    • Remove the back cover.
  5. Nokia 8260 Antenna Replacement: adım 5, 1 resimden 1.
    • Press the end of the battery towards the top of the phone.
  6. Nokia 8260 Antenna Replacement: adım 6, 1 resimden 1.
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
  7. Nokia 8260 Antenna Replacement, Antenna: adım 7, 1 resimden 1.
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
  8. Nokia 8260 Antenna Replacement: adım 8, 1 resimden 1.
    • Pry open the antenna door by pulling down the top of the spudger
  9. Nokia 8260 Antenna Replacement: adım 9, 1 resimden 1.
    • Remove the antenna door.
  10. Nokia 8260 Antenna Replacement: adım 10, 1 resimden 1.
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Aaron Jen
1 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 27-94, Amido Spring 2010 Cal Poly, Team 27-94, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S27G94
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 2,220
