Ana içeriğe geç
Nokia 8260 Microphone Replacement
Neye ihtiyacın var
  1. Nokia 8260 Microphone Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the cell phone.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 8260 Microphone Replacement: adım 2, 1 resimden 1.
    • Press down on the round button on the back cover of the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 8260 Microphone Replacement: adım 3, 1 resimden 1.
    • Slide the back cover down while still pressing the button.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 8260 Microphone Replacement: adım 4, 1 resimden 1.
    • Remove the back cover.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia 8260 Microphone Replacement: adım 5, 1 resimden 1.
    • Press the end of the battery towards the top of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia 8260 Microphone Replacement: adım 6, 1 resimden 1.
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
    FixBot'a Sor
    Yorum Ekle
  7. Nokia 8260 Microphone Replacement, Antenna: adım 7, 1 resimden 1.
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
    FixBot'a Sor
    Yorum Ekle
  8. Nokia 8260 Microphone Replacement: adım 8, 1 resimden 1.
    • Pry open the antenna door by pulling down the top of the spudger
    FixBot'a Sor
    Yorum Ekle
  9. Nokia 8260 Microphone Replacement: adım 9, 1 resimden 1.
    • Remove the antenna door.
    FixBot'a Sor
    Yorum Ekle
  10. Nokia 8260 Microphone Replacement: adım 10, 1 resimden 1.
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
    FixBot'a Sor
    Yorum Ekle
  11. Nokia 8260 Microphone Replacement, Circuit Board: adım 11, 1 resimden 1.
    • Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
    • The two bottom screws are longer than the upper three.
    FixBot'a Sor
    Yorum Ekle
  12. Nokia 8260 Microphone Replacement: adım 12, 1 resimden 1.
    • Remove the back covering.
    FixBot'a Sor
    Yorum Ekle
  13. Nokia 8260 Microphone Replacement: adım 13, 1 resimden 1.
    • Remove the two screws at the top.
    FixBot'a Sor
    Yorum Ekle
  14. Nokia 8260 Microphone Replacement: adım 14, 1 resimden 1.
    • Remove the metal plating and the circuit board.
    • There is nothing holding the rest of the phone together. Handle the rest of the phone carefully.
    • The LCD will be attached to the circuit board.
    FixBot'a Sor
    Yorum Ekle
  15. Nokia 8260 Microphone Replacement, Keypad: adım 15, 1 resimden 1.
    • Remove the plastic border lying on the keypad.
    FixBot'a Sor
    Yorum Ekle
  16. Nokia 8260 Microphone Replacement: adım 16, 1 resimden 1.
    • Remove the keypad.
    • Depending on what you are doing, you can take out or leave the buttons to the keypad in the front casing.
    FixBot'a Sor
    Yorum Ekle
  17. Nokia 8260 Microphone Replacement, Microphone: adım 17, 1 resimden 1.
    • Remove the microphone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Aaron Jen
1 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 27-94, Amido Spring 2010 Cal Poly, Team 27-94, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S27G94
4 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 35
Her zaman: 1,588
