Ana içeriğe geç
Nokia 8260 Speaker Replacement
Neye ihtiyacın var
  1. Nokia 8260 Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the cell phone.
    FixBot'a Sor
  2. Nokia 8260 Speaker Replacement: adım 2, 1 resimden 1.
    • Press down on the round button on the back cover of the phone.
    FixBot'a Sor
  3. Nokia 8260 Speaker Replacement: adım 3, 1 resimden 1.
    • Slide the back cover down while still pressing the button.
    FixBot'a Sor
  4. Nokia 8260 Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the back cover.
    FixBot'a Sor
  5. Nokia 8260 Speaker Replacement: adım 5, 1 resimden 1.
    • Press the end of the battery towards the top of the phone.
    FixBot'a Sor
  6. Nokia 8260 Speaker Replacement: adım 6, 1 resimden 1.
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
    FixBot'a Sor
  7. Nokia 8260 Speaker Replacement, Antenna: adım 7, 1 resimden 1.
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
    FixBot'a Sor
  8. Nokia 8260 Speaker Replacement: adım 8, 1 resimden 1.
    • Pry open the antenna door by pulling down the top of the spudger
    FixBot'a Sor
  9. Nokia 8260 Speaker Replacement: adım 9, 1 resimden 1.
    • Remove the antenna door.
    FixBot'a Sor
  10. Nokia 8260 Speaker Replacement: adım 10, 1 resimden 1.
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
    FixBot'a Sor
  11. Nokia 8260 Speaker Replacement, Circuit Board: adım 11, 1 resimden 1.
    • Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
    • The two bottom screws are longer than the upper three.
    FixBot'a Sor
  12. Nokia 8260 Speaker Replacement: adım 12, 1 resimden 1.
    • Remove the back covering.
    FixBot'a Sor
  13. Nokia 8260 Speaker Replacement: adım 13, 1 resimden 1.
    • Remove the two screws at the top.
    FixBot'a Sor
  14. Nokia 8260 Speaker Replacement: adım 14, 1 resimden 1.
    • Remove the metal plating and the circuit board.
    • There is nothing holding the rest of the phone together. Handle the rest of the phone carefully.
    • The LCD will be attached to the circuit board.
    FixBot'a Sor
  15. Nokia 8260 Speaker Replacement, Speaker: adım 15, 1 resimden 1.
    • Remove the speaker.
    FixBot'a Sor
Sonuç
Aaron Jen
1 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 27-94, Amido Spring 2010 Cal Poly, Team 27-94, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S27G94
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 70
Her zaman: 2,267
