Ana içeriğe geç
Nokia 8265 Keypad Replacement
Neye ihtiyacın var
  1. Nokia 8265 Keypad Replacement, Keypad: adım 1, 1 resimden 1.
    • Using a plastic opening tool, wedge the tip of the tool into the side of the phone's faceplate
    • To pry open, wiggle/twist the tip of the tool, until faceplate pops up.
  2. Nokia 8265 Keypad Replacement: adım 2, 1 resimden 1.
    • Once popped off, remove the faceplate entirely, exposing the keypad.
  3. Nokia 8265 Keypad Replacement: adım 3, 1 resimden 1.
    • You can pick up the keypad with ease, as it is not attached to the phone itself.
  4. Nokia 8265 Keypad Replacement: adım 4, 1 resimden 1.
    • To clean keypad if it is not functioning properly, use a cloth to wipe away any spills, or water damage
Sonuç
If cleaning off keypad does not work, insert your new keypad, and follow steps in reverse order to reassemble your device.
Jack
1 İtibar
4 adet Kılavuz yazıldı
Ekip
SUNY Cortland, Team 1-1, Getto Spring 2012 SUNY Cortland, Team 1-1, Getto Spring 2012 üyesi
SUNYCORT-GETTO-S12S1G1
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 816
