Ana içeriğe geç
Nokia 8265 Logic Board Replacement
Neye ihtiyacın var
  1. Nokia 8265 Logic Board Replacement, Logic Board: adım 1, 1 resimden 1.
    • Start by removing the face plate of the phone with a plastic tool.
    • Once plastic tool is wedged into the side of the phone, twist and leverage the face plate off.
  2. Nokia 8265 Logic Board Replacement: adım 2, 1 resimden 1.
    • Once the face plate is off, you will have exposed the keypad.
  3. Nokia 8265 Logic Board Replacement: adım 3, 1 resimden 1.
    • Simply remove the keypad from on top of the phone, and place it off to the side, leaving just the phone itself remaining
  4. Nokia 8265 Logic Board Replacement: adım 4, 1 resimden 1.
    • Taking a very small screwdriver, carefully unscrew the six screws attaching the top layer of the screen from the body of the phone.
    • Make sure to remember what screw goes where.
  5. Nokia 8265 Logic Board Replacement: adım 5, 1 resimden 1.
    • Once the six screws are removed, you may take off the screen section of the phone, exposing the inner workings of the cell phone.
    • The screen section will be able to be removed after Step 4 is finished.
  6. Nokia 8265 Logic Board Replacement: adım 6, 1 resimden 1.
    • Be careful when removing the Logic Board from the body, lifting it with fingers on both sides to prevent damage of the Logic Board.
    • Separate the Logic Board from the main body of the device.
  7. Nokia 8265 Logic Board Replacement: adım 7, 1 resimden 1.
    • Insert in the replacement Logic Board, setting the Logic Board carefully back into place.
  8. Nokia 8265 Logic Board Replacement: adım 8, 1 resimden 1.
    • Set the screen carefully over the body of the phone, avoiding any sliding on the Logic board
  9. Nokia 8265 Logic Board Replacement: adım 9, 1 resimden 1.
    • Replace screws in the corresponding slots, tightening them till they are not loose.
  10. Nokia 8265 Logic Board Replacement: adım 10, 1 resimden 1.
    • Replace keypad onto the device
  11. Nokia 8265 Logic Board Replacement: adım 11, 1 resimden 1.
    • Lastly, you can place the cover onto the phone. You will know when it is in place if you hear a click after placing it in.
Bitiş Çizgisi
Jack
1 İtibar
4 adet Kılavuz yazıldı
Ekip
SUNY Cortland, Team 1-1, Getto Spring 2012 SUNY Cortland, Team 1-1, Getto Spring 2012 üyesi
SUNYCORT-GETTO-S12S1G1
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 1,192
