Ana içeriğe geç
Nokia 8290 Adhesive White Film Replacement
Neye ihtiyacın var
  1. Nokia 8290 Adhesive White Film Replacement, Front Cover: adım 1, 3 resimden 1. Nokia 8290 Adhesive White Film Replacement, Front Cover: adım 1, 3 resimden 2. Nokia 8290 Adhesive White Film Replacement, Front Cover: adım 1, 3 resimden 3.
    • Locate the small button on the top of the phone.
    • Depress the button.
    • With your other hand, pull the front cover away from the phone.
  2. Nokia 8290 Adhesive White Film Replacement, Circuit Board: adım 2, 3 resimden 1. Nokia 8290 Adhesive White Film Replacement, Circuit Board: adım 2, 3 resimden 2. Nokia 8290 Adhesive White Film Replacement, Circuit Board: adım 2, 3 resimden 3.
    • Remove all six 5.3 mm long T6 screws.
    • Remove the circuit board/faceplate sub-assembly from the back of the phone.
    • Take care to place screws in a safe location.
  3. Nokia 8290 Adhesive White Film Replacement: adım 3, 3 resimden 1. Nokia 8290 Adhesive White Film Replacement: adım 3, 3 resimden 2. Nokia 8290 Adhesive White Film Replacement: adım 3, 3 resimden 3.
    • Using your fingers, pull the small plastic tab away from the circuit board/faceplate sub-assembly.
    • Rotate the faceplate away from the circuit board.
    • Gently remove the faceplate from the circuit board, taking care to not break the small plastic tab on the other side of the sub-assembly.
  4. Nokia 8290 Adhesive White Film Replacement, Adhesive White Film: adım 4, 3 resimden 1. Nokia 8290 Adhesive White Film Replacement, Adhesive White Film: adım 4, 3 resimden 2. Nokia 8290 Adhesive White Film Replacement, Adhesive White Film: adım 4, 3 resimden 3.
    • Hold the faceplate with the adhesive film facing upwards.
    • Use the spudger to pry the adhesive film away. This can be done by working the tool back and forth underneath the film.
    • It is easiest to begin in the upper left corner.
  5. Nokia 8290 Adhesive White Film Replacement: adım 5, 3 resimden 1. Nokia 8290 Adhesive White Film Replacement: adım 5, 3 resimden 2. Nokia 8290 Adhesive White Film Replacement: adım 5, 3 resimden 3.
    • Continue to loosen the film with the spudger.
    • Once the film has been mostly loosened, you can peel away the film.
    • Once the film has been removed, the microphone may fall out, if so, place it aside until all other repairs are finished.
Sonuç
Austin Culberson
87 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 15-3, Benson Fall 2012 Clemson, Team 15-3, Benson Fall 2012 üyesi
CLEM-BENSON-F12S15G3
3 Üyeler
21 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 332
