Ana içeriğe geç
Nokia 8390 Charging Port Replacement
Neye ihtiyacın var
  1. Nokia 8390 Charging Port Replacement, Back Cover: adım 1, 1 resimden 1.
    • Locate the button on the bottom of the back cover.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 8390 Charging Port Replacement: adım 2, 3 resimden 1. Nokia 8390 Charging Port Replacement: adım 2, 3 resimden 2. Nokia 8390 Charging Port Replacement: adım 2, 3 resimden 3.
    • Depress the button with your finger.
    • While the button is depressed, slide the back cover off of the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 8390 Charging Port Replacement, Outer Case: adım 3, 3 resimden 1. Nokia 8390 Charging Port Replacement, Outer Case: adım 3, 3 resimden 2. Nokia 8390 Charging Port Replacement, Outer Case: adım 3, 3 resimden 3.
    • Grasp the top and bottom of the front cover.
    • Grasp the phone body with your other hand.
    • Lightly pull the casing off of the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 8390 Charging Port Replacement, Motherboard: adım 4, 3 resimden 1. Nokia 8390 Charging Port Replacement, Motherboard: adım 4, 3 resimden 2. Nokia 8390 Charging Port Replacement, Motherboard: adım 4, 3 resimden 3.
    • Locate the six star-shaped screws on the phone.
    • Note: There are two on the bottom end, two in the middle, and two on the top end.
    • Remove these screws using the screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia 8390 Charging Port Replacement: adım 5, 3 resimden 1. Nokia 8390 Charging Port Replacement: adım 5, 3 resimden 2. Nokia 8390 Charging Port Replacement: adım 5, 3 resimden 3.
    • Grab the top and bottom of the phone casing.
    • Carefully pull the motherboard apart from the bottom casing.
    • The circuit board should be divided into two parts.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia 8390 Charging Port Replacement: adım 6, 3 resimden 1. Nokia 8390 Charging Port Replacement: adım 6, 3 resimden 2. Nokia 8390 Charging Port Replacement: adım 6, 3 resimden 3.
    • Grab the top and bottom of the remaining casing.
    • Carefully pull apart the casing from the circuit board.
    FixBot'a Sor
    Yorum Ekle
  7. Nokia 8390 Charging Port Replacement: adım 7, 1 resimden 1.
    • The circuit board should be divided into three parts, completely separate from the back casing, as shown.
    FixBot'a Sor
    Yorum Ekle
  8. Nokia 8390 Charging Port Replacement, Charging Port: adım 8, 3 resimden 1. Nokia 8390 Charging Port Replacement, Charging Port: adım 8, 3 resimden 2. Nokia 8390 Charging Port Replacement, Charging Port: adım 8, 3 resimden 3.
    • Hold back of phone in hand so that hand is not covering any parts.
    • Grasp charge port with thumb.
    • Pull out with hand.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Clinton
57 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-5, Benson Fall 2012 Clemson, Team 14-5, Benson Fall 2012 üyesi
CLEM-BENSON-F12S14G5
3 Üyeler
29 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 672
