Ana içeriğe geç
Nokia 8390 Motherboard Replacement
Neye ihtiyacın var
  1. Nokia 8390 Motherboard Replacement, Back Cover: adım 1, 1 resimden 1.
    • Locate the button on the bottom of the back cover.
  2. Nokia 8390 Motherboard Replacement: adım 2, 3 resimden 1. Nokia 8390 Motherboard Replacement: adım 2, 3 resimden 2. Nokia 8390 Motherboard Replacement: adım 2, 3 resimden 3.
    • Depress the button with your finger.
    • While the button is depressed, slide the back cover off of the phone.
  3. Nokia 8390 Motherboard Replacement, Outer Case: adım 3, 3 resimden 1. Nokia 8390 Motherboard Replacement, Outer Case: adım 3, 3 resimden 2. Nokia 8390 Motherboard Replacement, Outer Case: adım 3, 3 resimden 3.
    • Grasp the top and bottom of the front cover.
    • Grasp the phone body with your other hand.
    • Lightly pull the casing off of the phone.
  4. Nokia 8390 Motherboard Replacement, Keypad: adım 4, 3 resimden 1. Nokia 8390 Motherboard Replacement, Keypad: adım 4, 3 resimden 2. Nokia 8390 Motherboard Replacement, Keypad: adım 4, 3 resimden 3.
    • Lightly peel the keypad off of the phone.
  5. Nokia 8390 Motherboard Replacement, Motherboard: adım 5, 3 resimden 1. Nokia 8390 Motherboard Replacement, Motherboard: adım 5, 3 resimden 2. Nokia 8390 Motherboard Replacement, Motherboard: adım 5, 3 resimden 3.
    • Locate the six star-shaped screws on the phone.
    • Note: There are two on the bottom end, two in the middle, and two on the top end.
    • Remove these screws using the screwdriver.
  6. Nokia 8390 Motherboard Replacement: adım 6, 3 resimden 1. Nokia 8390 Motherboard Replacement: adım 6, 3 resimden 2. Nokia 8390 Motherboard Replacement: adım 6, 3 resimden 3.
    • Grab the top and bottom of the phone casing.
    • Carefully pull the motherboard apart from the bottom casing.
    • The circuit board should be divided into two parts.
  7. Nokia 8390 Motherboard Replacement: adım 7, 3 resimden 1. Nokia 8390 Motherboard Replacement: adım 7, 3 resimden 2. Nokia 8390 Motherboard Replacement: adım 7, 3 resimden 3.
    • Grab the top and bottom of the remaining casing.
    • Carefully pull apart the casing from the circuit board.
  8. Nokia 8390 Motherboard Replacement: adım 8, 1 resimden 1.
    • The circuit board should be divided into three parts, completely separate from the back casing, as shown.
Sonuç
Clinton
57 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-5, Benson Fall 2012 Clemson, Team 14-5, Benson Fall 2012 üyesi
CLEM-BENSON-F12S14G5
3 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 8
Her zaman: 489
