Ana içeriğe geç
Nokia Asha 201 Audio Jack Replacement
Neye ihtiyacın var
  1. Nokia Asha 201 Audio Jack Replacement, Audio Jack: adım 1, 1 resimden 1.
    • Remove the white case by popping apart the front and back with your finger.
  2. Nokia Asha 201 Audio Jack Replacement: adım 2, 1 resimden 1.
    • Remove the battery by taking it out with your fingers.
  3. Nokia Asha 201 Audio Jack Replacement: adım 3, 1 resimden 1.
    • Remove the two 5.5mm screws by using the T6 screwdriver.
  4. Nokia Asha 201 Audio Jack Replacement: adım 4, 1 resimden 1.
    • Use the blue plastic opening tool to remove the front of the white case.
  5. Nokia Asha 201 Audio Jack Replacement: adım 5, 1 resimden 1.
    • Remove the keyboard using your fingers and set aside.
  6. Nokia Asha 201 Audio Jack Replacement: adım 6, 1 resimden 1.
    • Unscrew the two 5.5mm screws near the bottom of the device on either side using the T6 screwdriver.
  7. Nokia Asha 201 Audio Jack Replacement: adım 7, 1 resimden 1.
    • Separate the black plastic internal case from the screen by prying with the blue plastic opening tool.
  8. Nokia Asha 201 Audio Jack Replacement: adım 8, 1 resimden 1.
    • The black plastic cover should now be separated from the motherboard. Replace the audio jack by removing it with your fingers.
Sonuç
Betsy Walker
157 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G3, Leahy Fall 2019 USF Tampa, Team S1-G3, Leahy Fall 2019 üyesi
USFT-LEAHY-F19S1G3
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 170
