Ana içeriğe geç
Nokia Asha 201 Screen Replacement
Neye ihtiyacın var
  1. Nokia Asha 201 Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Remove back cover of device by pressing firmly and sliding the cover off.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia Asha 201 Screen Replacement: adım 2, 1 resimden 1.
    • Using your finger, lift up on battery to remove from the device.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia Asha 201 Screen Replacement: adım 3, 1 resimden 1.
    • Using a screwdriver, remove the two screws from the back case.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia Asha 201 Screen Replacement: adım 4, 1 resimden 1.
    • Pry off the front case using a iFixit opening tool.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia Asha 201 Screen Replacement: adım 5, 1 resimden 1.
    • Remove the Keyboard with your hands.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia Asha 201 Screen Replacement: adım 6, 1 resimden 1.
    • Remove the four screws pictured here.
    FixBot'a Sor
    Yorum Ekle
  7. Nokia Asha 201 Screen Replacement: adım 7, 1 resimden 1.
    • Using the iFixit opening tool, separate the screen from motherboard.
    FixBot'a Sor
    Yorum Ekle
    • Unplug your old screen from your phone, unpack your new one and gently plug in the new screen. Make sure you plug in the screen just like the old one was placed in the phone.
    FixBot'a Sor
    Yorum Ekle
  8. Nokia Asha 201 Screen Replacement: adım 9, 1 resimden 1.
    • After plugging in the new screen put back the screen onto the motherboard.
    FixBot'a Sor
    Yorum Ekle
  9. Nokia Asha 201 Screen Replacement: adım 10, 1 resimden 1.
    • Use a philips #00 screwdriver to put back the four 3.5 mm screws trays pictured here.
    FixBot'a Sor
    Yorum Ekle
  10. Nokia Asha 201 Screen Replacement: adım 11, 1 resimden 1.
    • Using your fingers place the keyboard back like in the picture.
    FixBot'a Sor
    Yorum Ekle
  11. Nokia Asha 201 Screen Replacement: adım 12, 1 resimden 1.
    • Using your fingers and the Phillips opening tool reposition and adjust the front case onto the phone.
    FixBot'a Sor
    Yorum Ekle
  12. Nokia Asha 201 Screen Replacement: adım 13, 1 resimden 1.
    • Using the Phillips #0 screwdriver, screw back in the two screws to the back case.
    FixBot'a Sor
    Yorum Ekle
  13. Nokia Asha 201 Screen Replacement: adım 14, 1 resimden 1.
    • Using your fingers put back the battery in the back of the phone properly.
    FixBot'a Sor
    Yorum Ekle
  14. Nokia Asha 201 Screen Replacement: adım 15, 1 resimden 1.
    • Slide back in the phone cover to the back of the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Replacing Nokia Asha 201 screen takes several steps. These steps should be followed precisely to have the screen replaced without complications. Each step should be done before start doing the next step. After you’re done following these steps, you should start reassembling the device. To reassemble the device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Ekip
USF Tampa, Team S1-G3, Leahy Fall 2019 USF Tampa, Team S1-G3, Leahy Fall 2019 üyesi
USFT-LEAHY-F19S1G3
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 39
Her zaman: 921
