Ana içeriğe geç
Nokia Classic 2600c-2b Battery Replacement
Neye ihtiyacın var
  1. Nokia Classic 2600c-2b Battery Replacement, Battery: adım 1, 2 resimden 1. Nokia Classic 2600c-2b Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Nokia Classic 2600c-2b Battery Replacement: adım 2, 1 resimden 1.
    • Remove the back cover to expose the battery.
  3. Nokia Classic 2600c-2b Battery Replacement: adım 3, 2 resimden 1. Nokia Classic 2600c-2b Battery Replacement: adım 3, 2 resimden 2.
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out.
    • Follow the instructions in reverse order to reassemble the phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ian VanZandt
654 İtibar
5 adet Kılavuz yazıldı
Ekip
James Madison, Team 3-1, Klein Spring 2012 James Madison, Team 3-1, Klein Spring 2012 üyesi
JMU-KLEIN-S12S3G1
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 732
